Old 07-11-2006, 09:21 PM
mod mod is offline
Question home system
i know this dont belong here but i have a stereo at home it came with 2 detachable speakers and it has 2 positive and negatives plus to put the wires in my question is can i get all the bass notes to a sub iv got laying around
Old 07-11-2006, 10:08 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: home system
what brand stereo is it?
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 07-11-2006, 10:15 PM
mod mod is offline
Re: home system
it is koss i want to know if i can take it apart and find a way to get bass notes to a 8" sub
Old 07-11-2006, 10:28 PM
kcg795 kcg795 is offline
Re: home system
What I did one time is connect the speaker outs to another stereo amplifier and connected that to a subwoofer. For the outputs on that amplifier, I tied the Rights and Lefts together to get Mono for the subwoofer. You basically keep the main speakers connected to your stereo while using a second amplifier to power the sub. It could be a piece of shit stereo from a garage sale. I used an old RCA and got plenty of bass to my sub.
Old 07-11-2006, 10:33 PM
mod mod is offline
Re: home system
from looking at the back there is those slots right ell the right one is wired to the sub and the left is wired to four speakers because i thought the right had a little bit more bass
Old 07-11-2006, 11:52 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: home system
Ok, first off you need an enclosure for the sub, and amp for it, and a crossover.
A crossover splits up the frequencys so the subwoofer only sees what it can play, normally 15-80ish hertz. You need the amp to power the subwoofer.
They make amps called "Plate amps" that are specifically for home theater sub duty and have a crossover built into them.
*look here*
http://www.partsexpress.com/pe/showd...number=300-784
You also need an enclosure for the sub, whether it be sealed or ported.
So if you want to do this you would take the wires from the stereo into the high level inputs on the plate amp. The plate amp mounts in the box for the sub and is wired to the sub in whatever config you desire (make sure to stay in the rated specs). Set the crossover settings to the desired settings and there you have some more lowend.
Old 07-12-2006, 08:36 AM
PaulD'sRevenge PaulD'sRevenge is offline
Banned
Re: home system
balls ... I think you're missing his point. I doubt he wants to BUY anything, just hook up what he has. Some amps will let you do that (called trimode), some amps won't. If you try it and fail, it may blow the amp up - good luck.
Old 07-12-2006, 12:13 PM
Re: home system
Opps, my bad...
