Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-11-2006, 09:02 PM
stephenp stephenp is offline
Send a message via AIM to stephenp
280zx performance parts list
To start this is the 280zx project i started at thew end of last year and have been wrenching on it ever since...
CAR:
1979 280zx 2+2
ENGINE:
l28 bored 1mm over
balanced rotating assembly
race preped rods
high volume/pressure oil pump (motorsports)
Ferrea stainless steel undercut stemed valves
3 angle valve job
ported polished head
Schneider stage 2 race only cam
Schneider valve springs
60mm throttle body
60mm throttle body adapter
new radiator 3 row
nissan h2o pump
all new goodyear coolant hoses
eliminated heater and ac assembly
dual electric 16" fans (one pushes one pulls)
Battery trunk mount kit
Stainless steel bolt kit (nissan)
Titanium nismo oil cap
TURBO STUFF
Turbonetics t3/t4 stage 5 60 trim
Apexi AVC-R boost controller (holy functions)
Huge front mount intercooler (bar and plate)
2.5 & 2.75 intercooler piping
hks ssqv blow off valve
38mm waste gate
TRANSMISSON
1983 turbo 5 speed
ACT 240mm clutch unsprung 4 puck
Fidanza alluminum flywheel
Nissan roller pilot bearing (needle bearing)
Alluminum driveshaft
EXHAUST
3" downpipe (manderal bent stainless)
3" dumpout
3" stainless steel cat
3" stainless bellow (flex pipe)
3" stainless manderal over under axel pipe
3" stainless Borla muffler
EFI
1983 280zx turbo ecu and wiring
450 cc injectors
msd fuel pressure regulator
Unknown fuel modifier(thinking the apexi s afc)
huge alluminum fuel rail
Walboro 255 lph fuel pump
rci 8 gallon fuel cell
suspension
KYB GR2 alkl 4 corners
polyurethan bushings w/ adjustable camber kit and tension compression kit
stock springs (so much weight reduction even theyll be overly stiff)
1983 280zx turbo rack and pinion
oversized sway bars
front and rear strut bars
new wheel bearings front & rear
ball joints Tie rods (inner outer)
BRAKES
Drilled slotted rotors
stainless steel hoses
1983 turbo master cylinder
Raybesto hp brakes
stainless brake lines
BODY
removed all rust
primed & clear coated
shaved gas fill spot
rear window louvers
modified front clip for intercooler
hid headlights (with city lighting)
fully undercoated underside(rust free baby)
The only thing on this entire list that I do not already have or am waiting for in the mail is the fuel controller and the only other thing that I need after that is the tires...
And I think this is a pretty good summary.... There are so many odds and ends this is just the bulk of it (the more expensive stuff)
The total amount I spent on this project is ungoddly at over 12000 (considering without bonuses I gross just over 25000 a year) I poured my heart sole and all the money I could come up with (even a couple of loans (2600 in loans for the car. my 2 weeks vacation pay (took the cash with no vacation (going on 5 years no vacation am I a work aholic????)))
Well any way once I finally get it done Ill have to take some picks and you can all say what shit it looks like with the black overspray and super gutted interior then you can siut in awwe at what the engine bay looks like.....
So till next time
Old 07-11-2006, 10:05 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: 280zx performance parts list
your poor charging system.... other than that.. nice
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 07-12-2006, 06:39 AM
See thats what I get for only looking at a list of purchases and then adding what I think of... The alternator is a 1984 digi dash alternator (higher amps).
Forgot all about that so just pretend that is in the list. Along with the power supply wiring from a 1983 turbo 280zx(fuse box upgrade from the glass tube type).
Thanks for noticing..... Anything else I forot lol..... Mirrors from 83 turbo (still white lol) rear bumber from an 83 (2 peice instead of 1...)
Cut the hood vents to allow for the air to flow in better (origannaly pass. vents had a 2x4 hol;e cut out I enlaged to be similar to drivers side (also enlarged drivers side)
Also If I can get a good price Im gonna get a cowl hood scoop, only instead allowing air in, its gonna allow the heat from radiator out (tin shrouds to create ducts...)
Also this winter I plan to put on a wide body hood trunck and doors (all fiberglass) and making the bottom flat( fiberglass sheets with several louvers to allow air to cowl out....
Well gotta go
so till we meet again...
Old 07-12-2006, 05:09 PM
SilentNIght1647 SilentNIght1647 is offline
That's quite the list of stuff you've got their wouldn't it have been easier to drop in an SBC and call it good? A mildly modified 350 will make more power and torque than even a heavily L-series, oh well I'm a little biased but good luck on your project I'd like to see some pics.
Old 07-12-2006, 06:54 PM
DeleriousZ's Avatar
quiet you
Old 07-12-2006, 07:25 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Yea, we don't need another "lame ass 'undeserving' v8" in another z car, right delerious??
That's alot of mods, what kinda power are you hoping for anyways???
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 07-12-2006, 07:26 PM
DeleriousZ's Avatar
he can do what he wants, i think it's silly tho...
Old 07-12-2006, 08:23 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
2+2... man... long wheel base.
Pics???
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 07-12-2006, 09:25 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Originally Posted by -The Stig-
Pics???
f*cker never posts pics...i have been waiting for over a year for him to fix his digi camera. come on stevie!
ZedEx Crew Member #4
Old 07-14-2006, 02:28 PM
-The Stig-'s Avatar
On Fire!
Digi cameras are cheap. $100 can get you a decent digicam.
You would think... $12,000 spent on a car, you'd probably want to take some pictures of the process... or finished product...
Old 07-17-2006, 01:18 AM
Z Cars Fanatic
you'd think...
