'98 rear speaker removal help
i know you have to remove trim and stuff to get to the speakers but how do you do it? does anyone have a guide? i have already seen the ones you have to buy but my mom won't let me buy them, so is there any one who can help me out?
it would be greatly appreciated and if this info is needed, i have a '98 Z-24 |
Re: '98 rear speaker removal help
1) Lower the back seat, and remove the 4 clips that hold the plastic trim pieces to the rear dash.
2) Next, remove the 2 plastic trim pieces. To do this, pull them slightly toward you, and angle them toward the ground. The small clips that hold them in will pop out of place. 3) Pull the rear seat belts through the slots in the back deck, and then pull the slots inward a bit. This will allow the piece of rear deck that is under the sides to come free. 4) Now just start pulling, and jiggling it a bit. You may also need to bend the centre of the dash up slightly, being careful not to crease it. It will eventually slide out. 5)If you are trying to remove the rear speakers, simply push in the little clips that are facing you. You will need to disconnect the speaker wire connection. The factory speakers are held in by 4 screws. Remove those and the factory speakers will pop right out. 6) The Rear Speakers Are 6X9's, but you can either make or buy adapters so you can use a component speaker system. 7) Reinstall in reverse. Fig. 6: Removing the rear window panel trim Fig. 7: After removing the rear speaker and spacer assembly, ... Fig. 8: ... separate the speaker from the spacer by unfastening the retaining bolts |
when i try to get that piece off it gets hung up on the trim around the right and left rear windows, how do you get the trim off the side windows to get to that panel on top of the speakers
wow when did chevy get its head caught in its ass?
mine are in a steel supportive brace, held up by 2 metal hangers. you can reach them by sticking your head in the trunk. and do y'alls 3rd gens have round speakers? mine seats 6x9s
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles] Gone but not forgotten: 1995 Pontiac Grand Prix GTP[sold, 128k miles] 1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles] 1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles] 1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems] 1990 Hyundai Excel GL [died, 220k miles, died] |
mine had 6x9's when i went to replace them, im pretty sure they were stock....
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
they are still 6x9 but they are screwed in from the top so you cant remove them from the trunk even though you can see them clear as day from the trunk there is no way to get them out, so it sux
