Where is the coolant temperature sensor???
Hey everybody--I think I have a bad coolant temp sensor--the radiator fan is on all the time and the temp gauge stays on cold all the time. The heat is hot, though. Plus the check engine light is on.
Anyway, I can't find the coolant temp sensor. I have a '97 cav. Does anyone know where it is located on the engine? The coolant system is kind of nontraditional. Thanks. |
Re: Where is the coolant temperature sensor???
Fig. 1: The ECT sensor is located in the water outlet housing, adjacent to where the upper radiator hose connects to the engine Fig. 2: ECT sensor location-2.4L engine Fig. 3: ECT sensor location-1998-00 2.2L engine The Engine Coolant Temperature (ECT) sensor resistance changes in response to engine coolant temperature. The sensor resistance decreases as the coolant temperature increases, and increases as the coolant temperature decreases. This provides a reference signal to the PCM, which indicates engine coolant temperature. The signal sent to the PCM by the ECT sensor helps the PCM to determine spark advance, EGR flow rate, air/fuel ratio, and engine temperature. The ECT also is used for temperature gauge operation by sending it's signal to the instrument cluster. The ECT is a two wire sensor, a 5-volt reference signal is sent to the sensor and the signal return is based upon the change in the measured resistance due to temperature. TESTING See Figures 4, 5 and 6 Fig. 4: Detach the connector on the ECT sensor Fig. 5: Measure the resistance across the ECT terminals on the sensor Fig. 6: ECT sensor resistance value chart
Wow! Thanks for the info--I really appreciate it. I will test it first according to those directions to make sure that it is bad.
man wtf do you have a ton of engine pics on your computer lol
what a hacked version of the haynes book. There is some program called (something)all can't remember what the first word is. Need to get a version of that
