Old 07-11-2006, 06:33 PM
Donzi4me Donzi4me is offline
Service Engine On... Transmission?? MAF??
Car ocassionally shifts really hard. Not all the time. And the service engine light is on. Noticed today that also a whine is coming from under the hood and it is not shifting into overdrive. Shut the car off and restart it, and it shifts fine,still no overdrive, no whine, but the light is on. Drive about 15 miles and it will shift hard again.
Stopped by Auto Zone to have it scanned. Code came up P102... Mass air flow sensor. He could not read tranny codes. The MAF sensor may be bad, but I can't believe that would cause the shifting problems. After looking on this forum, it sounds like the PCM sticking in the tranny. Car is a 2000 GT with 120k on it.
Any help would be appreciated.
I added some seafoam from NAPA and it helped for awhile, but it still does it.
Old 07-11-2006, 07:00 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Service Engine On... Transmission?? MAF??
The MAF sensor could cause erratic shifting but it sounds more like you have other internal problems with the tranny. Possible PCS or 3-4 shift solenoid at the valve body. To scan for tranny error codes you need an odb-ii scanner that is trans. capable. Also, since you are missing OD (4th) you could have a mechanical problem like the 4th clutch or a spline.
On the MAF sensor error I would reset the PCM and see if it repeats. But P0102 is typically a bad MAF sensor.
Timeslip 08/12/06
AF Community Guidelines
Old 07-11-2006, 07:01 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with bnaylor 100%
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-11-2006, 07:37 PM
wlkjr's Avatar
wlkjr wlkjr is offline
I'm with you fellers.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 07-11-2006, 08:07 PM
Unhappy Re: Service Engine On... Transmission?? MAF??
Looks like I'll take it to a transmission shop and get them to scan it. I know that tranny work can be some major $$$.
But I've already got alot of other repairs done already, so it's a question of do I sink more $$$ into it or cut my losses. Other things needed are the fuel pump sensor since the gas guage doesn't work, the struts should be replaced, as well as new tires and brakes.
Just replaced 3 hubs (thanks Rich), ignition switch because it would not come out of park, 2 window motors.
Thanks for the replies...
Old 07-11-2006, 10:26 PM
troy1 troy1 is offline
AF -Advisor
I guess it depends on if the car is in good shape and if you like it. 2K for a tranny is lot cheaper than a newer car which could give you the same problems. If you don’t want to car try and sell it as is or find a junk yard tranny and trade it off. Me personally if the car was in good shape I would fix it regardless if I liked it or not. The I'm bored of it or I don’t like it anymore so lets get a new on lead a lot of people into bad financial decisions. You have to look at the cost to fix vs. the valve of the car.
