Old 07-11-2006, 06:29 PM
conley69 conley69 is offline
dies when coming to a stop
have a 1988 2.8 cavalier and when i'm coming to a stop it wants to die so i have to keep a little gas on it so it won't and it has a weird smell and sometimes if it dies when i start it back up the engine idles really high and it will sputter sometimes too. can anyone help
Old 07-11-2006, 11:52 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: dies when coming to a stop
..triple post?
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 07-12-2006, 01:28 AM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
lol i guess we can ask u the same question huh cody?
ThE neW wHiP:
Old 07-12-2006, 12:17 PM
MrR0b0t0 MrR0b0t0 is offline
Haha true that. Its either dial-up or a 12 yr old kid. Either way the triple posting makes me not want to help em, not that I know how or anything.
'03 Cavalier 2.2 Ecotec 5 Spd Coupe
Old 07-14-2006, 09:26 AM
mccoy89z24 mccoy89z24 is offline
Assuming you have a auto tranny, it might be the tcc solenoid. From what I have read here and have been told, just unplug it when the tranny is cool. If disconnecting it helps then you need to replace it. There are a couple good links on this site as to how to change the tcc. Here is the directions on how to change it. I found this on either this site or maybe http://www.v6z24.com. This is another really good site for info. Sorry for not giving credit were credit is due. Will try better in the future to give author or any other info crediting the help.
TCC REMOVAL
It's a fairly easy job! You have the 125c tranny in that cav. Jack the drivers side front corner up till you can remove the wheel (place a jackstand under the car!) With the one corner raised you will not loose any fluid changing the solenoid. Now remove the inner splash shield. It is held on with several 7mm screws. Once thats removed you will see the diff side cover. You will also see the two tranny cooler lines coming in on the left side of the cover. They both will need to be removed. You will lose a little amount of fluid from them but nothing major. Now remove the bolts holding the side cover to the differential. The top ones may be hard to get but you can get them with patience. Now remove the cover. You'll be looking at the valve body now. On the bottom of the valve body you will see two wires running to a small round solenoid bolted with on bolt to the bottom of the valve body. Remove the bolt and cut the wires going to the solenoid (make sure to cut them as close the the solenoid as possible! Now take a small pick or hook tool and remove the plastic sleeve that most likely stuck in the valve body after you took the solenoid out. Now the aftermarket solenoid will look slightly different. The bracket may seem larger. This is because several aftermarket solenoids you must trim the bracket to fit your trans. The directions will show you where to cut depending on which tranny. Now match the colors of each wires and splice them to then ew solenoid using the provided non crimp connectors (most use these). now simply remove the old differential cover gsaket and replace the cover with a new gasket and reassemble it as it came apart. Make sure to hook the tranny lines back up! Now lower the vehicle and check the fluid level. You will most likely not have lost enough to make a difference on the stick.
Old 07-15-2006, 03:34 AM
noshun's Avatar
noshun noshun is offline
all together now
IAC valve - clean it
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
noshun's Avatar
also if the smell is rotten eggs like it's just fule hitting the cat
Old 07-15-2006, 02:42 PM
chevyguy93 chevyguy93 is offline
sounds like the tcc to me. i had to replace it on 2 of my vehicles. tho i didnt have to remove the tranny lines in order to get the bolts out, i just had to bend them a tad in order to squeeze the ratchet in there
2003 Grand Prix GT
1993 Cavalier 2.2L
