Old 07-11-2006, 05:27 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
mass air meter?
Can I use a 1993 cobra 70 mm mass air meter calibrated for 24# injectors with a A9L computer and harness with 24# injectors out of a 1989 mustang? or do i have to use a cobra computer?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 07-12-2006, 05:35 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: mass air meter?
You do not need the computer. As long as you have the matching injecters and meeter you'll be fine. Just make sure the 24#'s are blue and not yellow. Yellow=19's, blue=24's.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-12-2006, 04:33 PM
Re: mass air meter?
ok thanks, i got 24# injectors they are blue tops.
Old 07-12-2006, 07:52 PM
HiFlow5 0's Avatar
Stanger
Re: mass air meter?
Good luck
-2013 Ford Flex
-1999 Ford F150
