Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-11-2006, 05:25 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
bov question
A few days ago i put back my ICP and 1g BOV because i sold my hard ICP and my type rs BOV to make some money and go FMIC,but this sunday i took my car to the track and i ran low 16's, which sucks because last time i was allready runing 15.5 on stock ICP and 1g BOV, and only 2 psi more and i started looking arround the engine bay and i removed the recirculation pipe and i found out that my bov is always open, even at idle (800), when i step on the gas and starts boosting it just holds back, like the turbo spools up and boost goes up but no power. and the bov now has this wierd noise. is not the crispy whoosshhh. now it's like little kitten.
But my question is, is the bov suppossed to be oppen all the time? or is it time to get a new one?
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-11-2006, 05:36 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: bov question
From my understanding... the bov should only open when you let off the gas. If the valve where it would normally recirculate is always open then I would say you have a major ass boost leak back into your intake.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: bov question
No it's not supposed to be open all the time. Under boost it's supposed to be close to allow the boost to pass through the pipes. As soon as you left off the gas/shift it opens to release the excess boost in the pipes. So if it is staying open you definately need to get a new one.
1991 GSX 2.3 Stroker
Old 07-11-2006, 08:06 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: bov question
It will be open at idle if idle vac is strong enough to open the BOV against the spring pressure. Is this is in fact usually the case, and is why you shouldn't be running your BOV to atmosphere. About the change in sound, hard to say. If it is adjustable you may have to adjust it. What BOV is this again? "type rs" is meaningless to me.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-11-2006, 08:10 PM
Re: bov question
No i'm not venting, i just removed it to see what was going on, and it's the 1g bov, i stopped using it for about 3 months i think.
what would make the vac pressure strong? high idle? so i guess i'll just get me a new one they arent expensive, cause i just scored me an ebay FMIC for 237 shipped.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN%3AIT&rd=1
-MODS-
Old 07-11-2006, 08:43 PM
NateS's Avatar
Re: bov question
Niceee one on the fmic. That is the same fmic that I and a few others have. If you don't know already... It will not bolt directly up. There are at least 2 threads on installing the ssautochrome fmic(we had a group buy not to long ago) Sorry, off your thread topic but, I thought I would tell you now. I don't have the links for the threads but just search for them.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 07-11-2006, 08:55 PM
Re: bov question
i think i remember reading about it. but i wasnt sure if it was this one. but thanks for letting me know. but at least i know people made it fit in a dsm so that mean it will fit in my dsm too. now i just have to go and order the 16g from turbochargers.com( hopelly i can charge it to my credit card) i was gonna pay for the FMIC with my credit card but paypal didnt let me, it let me add debit card but not credit card.
-MODS-
Old 07-11-2006, 10:31 PM
AF - Advisor
Re: bov question
It's not that your vac is too high, my point was that the BOV is behaving exactly as it should Especially a 1g BOV. As long as it is staying closed under boost it won't affect WOT performance.
Kevin Jewer
Old 07-11-2006, 10:39 PM
SLoe's Avatar
SLoe SLoe is offline
Re: bov question
BUT Keeevv, it doesn't go WOOOOOSH any more
Here is my 10 cents, whenever you are having these kind of problems, go back to the basics. Do a leak test first.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-12-2006, 09:55 AM
AF - Advisor
Re: bov question
LMAO, you just reminded me of my exwife. I'm not sure yet how I feel about that, but we'll deal with it later. So, I ran a RFL for a while in the 2g, and she liked it. When I swapped the 1g unit back on after I got sick of the constant and incurable leaks, she said in her busted half brazilian portugese broken ass engleesh, "Where's my POOOSH!?" One of the most quoted Portuglish comments she ever made. See, it's not all hatred and regret, there are some good memories...
Kevin Jewer
Old 07-12-2006, 12:07 PM
SLoe's Avatar
Re: bov question
SLOL @ POOOSH!
I run a turbo xs, non-rfl. I bought it before I found the net and learned that VTA is bad. I didn't notice any problems with it though, I have had too many other problems to notice if there are leaks
