Old 07-11-2006, 08:27 AM
2000GPGTBlue2dr 2000GPGTBlue2dr is offline
Unhappy 2000 Grand Prix GT stalling at stop
My Grand prix (3800 engine) is occasionally stalling at stop signs. Is this a fuel sending/ injection problem??? I watch the rpm gauge, and when I hit the brakes the gauge drops below 1000 rpms and sometimes it corrects itself and but sometimes it just drops to zero and the car turns off. I have no codes on the car whatsoever (checked it out with a handheld code reader I bought from Advance Auto). Has anyone else had this problem. Any help would be appreciated. Thanks!!!!!
Old 07-11-2006, 09:15 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 Grand Prix GT stalling at stop
You have one of three possible problems.
If stalling is only at low rpms or around idle possible defective idle air controller or just dirty. Try cleaning the IAC with carb or throttle body cleaner. Also, clean the seat where it mounts to the throttle body.
Second, it coud be an ignition related problem. So far maybe symptoms of a flaky crank position sensor (CKPS).
Third possibiity is a fuel delivery problem (not fuel injector). Check the fuel pressure at the Schader valve located at front fuel injector rail to see if in specs. Also, replacing the fuel filter won't hurt.
Timeslip 08/12/06
AF Community Guidelines
Old 07-12-2006, 08:57 PM
Well I cleaned the idle air controller- and man it was dirty (lots of black carbon deposits on it). The car no longer stalls at stops. It just turns off while it's sitting and idling. I think it's the fuel filter. I will change that out to see if that fixes the problem. Where is the crank position sensor (CKPS) located on my engine- is it easy to replace?? I read some other threads and people said a possible symptom for my problem is the vacuum lines on the intake manifold may be loose. I'm not sure how many there are and where they are all located to make sure they are on tight or not????
Old 07-12-2006, 09:08 PM
BNaylor's Avatar
Originally Posted by 2000GPGTBlue2dr
Well I cleaned the idle air controller- and man it was dirty (lots of black carbon deposits on it). The car no longer stalls at stops. It just turns off while it's sitting and idling. I think it's the fuel filter. I will change that out to see if that fixes the problem. Where is the crank position sensor (CKPS) located on my engine- is it easy to replace?? I read some other threads and people said a possible symptom for my problem is the vacuum lines on the intake mainfold may be loose. I'm not sure how many there are and where they are all located to make sure they are on tight or not????
Try the fuel filter first. Here is a procedure for location and changeout for the crank position sensor:
http://mykidz.net/GTP/CrankPosSensor.shtml
The main vacuum lines are located on the Throttle Body (TB) and Upper Intake Manifold (UIM). From the TB one goes to the fuel pressure regulator and the other to the purge valve. There is an accessory vacuum line that goes to the HVAC system. Vacuum related to the PCV valve is internal to the UIM so that will not be visible.
Timeslip 08/12/06
Old 07-14-2006, 01:58 PM
Grim4208 Grim4208 is offline
Man, I was having the same problems with my 2000 GT, I checked it out and it turned out to be the Mass Air Flow Sensor... I got it replaced for about 367 part and labor and it runs like a charm now.
Old 07-14-2006, 04:18 PM
amesjm0431 amesjm0431 is offline
I agree with Grim. I was having the same issue with my 2001 GTP and I changed the MAF and it worked great. It is pretty easy to do it yourself.
Old 07-17-2006, 08:17 AM
Thumbs up Re: 2000 Grand Prix GT stalling at stop
Yep. You guys are correct. It was the Mass Air Flow Sensor that was causing it to stall at idle and also when I would accelerate (because slowly but surely it was getting worse- before it would only stall at stops). I also replaced the fuel filter for good measure since it's original and I have 88000 miles. Now my car is back to normal. Thanks to everyone for their help.
Old 07-24-2006, 01:27 PM
iT90accord iT90accord is offline
Send a message via AIM to iT90accord Send a message via Yahoo to iT90accord
Where exactly is the Mass Air Flow Sensor located? Mines bad and needs replacing and it was at a mechanics and they said its under the engine cover by the manifold and that looks like the throttle body to me. Is the MAF in all the black casing for the air intake?
Live today like your dead tomorrow
02 Black WRX
17" Rota Gold Rims
HKS EBC
Blitz Nur Spec Exhaust
Tinted Headlights
More to come...
Old 07-24-2006, 01:34 PM
BNaylor's Avatar
It is the black module right on top of the throttle body. Two Torx safety screws hold it on. Here is one removed.
BTW - What year, model and engine Grand Prix? Make sure you get the right one for your year and engine.
Timeslip 08/12/06
Old 07-24-2006, 01:54 PM
Theres something else to it besides that sensor though. I think there is a part in the actual casing of the intake that is quite a bit bigger. I dont see how just that black sensor is $220.
Its a 2000 Grand Prix GT 3.8L
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 07-24-2006, 02:14 PM
BNaylor's Avatar
No there is not. The MAF sensor new from GM is expensive. $221.13 is the GM List price.
You could get a remanufactured one from one of those national auto parts stores for 1/2 the price but those have a high failure rate especilly is it is an A1 Cardone part.
Checkout ZZPerformance.com. They have the GM MAFs for around $119 plus shipping.
http://www.zzperformance.com/grand_p...ee46203e7acd96
Timeslip 08/12/06
Old 07-25-2006, 09:13 AM
Are those good quality ones at ZZperformance?
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 07-25-2006, 09:28 AM
BNaylor's Avatar
It is the GM OEM MAF sensor brand new not reman. I have never had a problem with any part I got from ZZP.
Timeslip 08/12/06
Old 07-25-2006, 10:02 AM
Thanx a bunch man I really appreciate the help
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 04-05-2011, 10:16 PM
kstorlien kstorlien is offline
Don't buy the MAF not made by GM. The cheap one lasted me 2 years and now I have to replace it again. I will be buying the GM part this time for sure.
