Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-11-2006, 01:52 AM
Backfire55 Backfire55 is offline
Question Boost on stock 1.8T??
Hey does anybody know how many PSI a stock Jetta 1.8T runs?
Old 07-12-2006, 02:41 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Boost on stock 1.8T??
what year?
99-01= 9psi
02-05= 13psi
Old 09-22-2006, 07:51 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
I know nothing about VWs. how much boost can a stock 03' 1.8t gls engine handle? what kind of turbo do they have? is the 03' considered a mk4? thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 10-09-2006, 11:04 PM
a 2003 jetta is a MK4..as far as your other questions i have no clue
Old 10-11-2006, 10:38 AM
Gotian Gotian is offline
Send a message via AIM to Gotian
they have a Ko3s if they are 2002+, it can boost up to 14.7 pounds without upgrading fuel, you add a 4 bar FPR and you can boost up to 25 pounds with tuning. I am boosting a peak of 20 pounds with my jetta. i dont suggest going above 25 pounds on a stock turbo because that is out of the efficiency range for it.
"Your car is a wind up toy" - Coworker into american cars
"Why cause it's an import?" - me
"No, cause its a rotary and it spins, d'uh" - coworker
Old 10-11-2006, 05:52 PM
Exclamation Re: Boost on stock 1.8T??
I've heard that just by chipping a jetta you can get more boost...But I dont understand, is the turbo linked into the computer?? also, any clue what kind of chips work and which ones to avoid?
Old 10-16-2006, 09:54 AM
They arent chips, per say, it's an upgraded program for your ECU which increases the Boost to 1bar (which is 14.7 pounds) The amount of boost produced by the turbo is electronically controlled. I am going to go with GIAC for my ECU tuning, but you could also go with APR which has a good program as well.
