| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
distributor woes
Well ill make a long story short
Car was running fine yet a very small rough idle so i go to the junkyard and get a new distributor off the old engine that died a few monthes back. So i take everything off and install it, great. I try to start the car, but to no prevail, i forgot to put the engine at TDC and the rotor wasnt on 1# piston. All i get is a trying engine and when i let go of the key i hear it all spin down then a slight klunk , just 1 klunk. Ive put on theold cap and rotor but to no prevail. What have i done. 1989 maxima 3.0 VG vg30e engine auto tranny new fuel filter, air filter plugs wires etc... |
Re: distributor woes
you need to time the engine get it at top dead centre (TDC) No 1 cyl timing mark on front crank pulley
you need to fit distributor so when it is fitted the rotor is pointing at No 1 spark lead note as distributor is fitted the rotor may turn if the drive is a gear take this into account in positioning rotor before fitting |
Thank you
![]() So to put the engine at TDC i take of the timing belt cover and have that little marking on the top on themain pulley? |
Rotate engine via crank bolt or by hand using accessory belts. TDC mark at crank pulley meets TDC pointer (in the belt cover) - when distr rotor points to cyl 1 ... as sparkeykev said. Your clunk may be unrelated... starter/ solenoid bad? See link pages below, find it all...
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
