Old 07-11-2006, 12:01 AM
airboss20 airboss20 is offline
Odbii P0101?
I have a 2001 Blazer ZR2 Widestance. Every once in a while, while driving long distances, I get a P0101 code. After a while the code will clear. I was able to get the code read at an AutoZone while the light was still on, and it read as a p0101. That's about all thehelp I got from them. I'm thinking that it has something to do with the MAF sensor? Help please!
Old 07-11-2006, 12:08 AM
TheBrettster TheBrettster is offline
AF Premium User
Re: Odbii P0101?
Thats your MAF Sensor. It may be dirty, try getting some intake cleaner and spray it all over your MAF sensor. Sometimes dirty and grime could get on it causing the sensor to display that.
Do you have a cold air intake or a k&n drop in filter?
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 07-11-2006, 01:07 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Odbii P0101?
Have you installed or reoiled a K&N filter lately?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-11-2006, 02:08 AM
AF Premium User
Re: Odbii P0101?
Yea the oil from the filter will get on the sensor causing poor performance and the error.
Old 07-11-2006, 02:23 AM
Re: Odbii P0101?
I've had a K&N OEM replacement "drop in" since January. I havn't recently re-oiled it.
Old 07-11-2006, 02:25 AM
Re: Odbii P0101?
I've had a K&N "drop in" oem replacement filter in it since January. I havn't re-oiled it yet.
Old 07-11-2006, 05:04 AM
AF Premium User
Re: Odbii P0101?
Yea same problem i had so i replaced it with the stock one and used the intake spray and just drenched my maf sensor and the code went away and i recently contact K&N about the issue as well.
Symptoms didn't show up till 6 months latter for me to.
Old 07-11-2006, 12:04 PM
BlazerLT's Avatar
AF -Advisor
Re: Odbii P0101?
Leave the K&N in there and blast the inside of the sensor with brake cleaner to clean the oil off of the sensor filament.
Reset the computer and you will be good to go.
Old 07-11-2006, 10:16 PM
kb3jhp kb3jhp is offline
Re: Odbii P0101?
use http://www.crcindustries.com/hd/cont...x?PN=05110&S=N this stuff just came out brake chock cleaner leaves oil and brke cleaner is to strong
Old 07-12-2006, 03:22 AM
AF Premium User
Re: Odbii P0101?
Brake Cleaner Can Never Be To Strong Intake or Carb Cleaner Works Just Fine For me.
