Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-10-2006, 10:11 PM
Michael B. Michael B. is offline
Talking P71 Transmission '99 Crown Vic
Ok, here's another..
My non AOD trans shifts smooth, but when the card heats up, I get some hesitation when i punch it to the floor. Again, only when it's hot.
In non OD, works perfect. I can live with this, but would like to know the cause.
I have changed the fluid, no difference.
Anything that I can try before contemplating an expensive trans job ?
Any help, gladly appreciated.
Michael B.
Old 07-11-2006, 10:47 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: P71 Transmission '99 Crown Vic
You have the 4R70W transmission. More than likely the forward clutch pack is getting ready to go. Maybe some additive will help for a little while, but eventually it will need to be repaired. Make sure the Transmission Range/ Manual Lever Positioning sensor is adjusted properly. With car in neutral, there are 2 little marks that need to be aligned with each other. These are located on the center of sensor and the outside of the sensor housing. They should be on top of the sensor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
