Old 07-10-2006, 06:57 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Driving lights
I have a set of older driving lights(still new in box)that I was thinking of installing as extra reverse lights. I'll install them to be independent of the factory lights. I opened the pack and it saw it doesn't use a relay. I know I've seen kits w/relays - what is better? What do the relays do for the system and what could happen w/o them?
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 07-11-2006, 12:24 PM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
Re: Driving lights
With a relay setup, you are using the power from the reverse lights (in this case) to turn the relay on so that the power can be drawn directly from the battery which would make the driving lights you have run on their own circuit. Without a relay you are putting extra load on the reverse light circuit.
Old 07-11-2006, 07:13 PM
Re: Driving lights
The lights won't be hooked to the truck's lights. They are going to be indepenent - hooked to power source - toggle switch.
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 07-12-2006, 08:00 PM
hunter01 hunter01 is offline
Re: Driving lights
Depending on the type of switch you use, over time you could melt the contacts in the switch if you don't use a relay.
Old 07-12-2006, 10:10 PM
rental blazer rental blazer is offline
Re: Driving lights
i have done this set up but i put a relay and inline fuse in my set-up and wired it so they automaticly turn off if i forget to turn em off by wiring it with the fusebox to the ing. it helps alot to have a set in back...but they look alot better on the 95-97 bumper due to the way you can tuck em in...
<a href="http://putfile.com/pic.php?pic=main/7/19223080738.jpg&s=f10" target="_blank"><img src="http://f10.putfile.com/thumb/7/19223080738.jpg" alt="Click to enlarge"></a>
<a href="http://putfile.com/pic.php?pic=main/7/19223052246.jpg&s=f10" target="_blank"><img src="http://f10.putfile.com/thumb/7/19223052246.jpg" alt="Click to enlarge"></a>
