Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-10-2006, 03:31 PM   #1
fngboy
Send a message via MSN to fngboy
Exclamation 1997 Dodge Neon SOHC radiator fan relay
so i have searched through the forums and there have been many answers to this question, but there is no place where anyone says the location of the radiator fan relay in the 97 neon sohc. in the haynes manuel it shows it in the fuse/relay box behind the battery, but when i looked there, it wasn't there, and there was no indication that it was ever there. so, we took a look at the fuses inside the car, and the relays that were in there wern't the right ones either. so my main question is
does anyone know the whereabouts of the Radiator Fan Relay in the 1997 Dodge Neon SOHC?
fngboy is offline   Reply With Quote
Old 07-10-2006, 10:59 PM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 1997 Dodge Neon SOHC radiator fan relay
1997-1999 Neons, the radiator fan relay is located on the driver's-side frame rail (see pic below)... If you want to get at it from the top, I would suggest remove the battery and battery tray.
*Thanks to NeonStyl for the info and pic.
das2123 is offline   Reply With Quote
