Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-10-2006, 01:16 AM
jonnyboy9012's Avatar
jonnyboy9012 jonnyboy9012 is offline
Send a message via AIM to jonnyboy9012
Turbo oilline setup???
Sorry im so ignorant about turbos. Hopefully only one last question. I need to know if the turbo will pickup oil all by itself or will i have to install the pickup line into a pressurized port in the motor. Thank you.
Current Cars and Specs:
1972 chevrolet nova
402 Chevy Big Block
Borg Warner 5 speed trans.
Future Mods:
Procharger super charger
NOS Carb Plate Nitrous System (150 Shot)
Hoosier pro street radials
2005 Chrysler PT Cruiser 2.4 Liter (soon to be traded for 96 TSI AWD)
Garret T04-E Turbo
"Quick Flow" Air Filter
Complete Custom Setup
6psi@219whp
URC Member #1
Old 07-10-2006, 05:19 PM
534BC 534BC is offline
Re: Turbo oilline setup???
Have to run a pressure line to it, and a drain line away from it.
Many connections on a turbo.
Old 07-10-2006, 05:31 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Pretty much, the turbo will not suck up the oil on it's own.
Old 07-11-2006, 02:31 AM
UncleBob UncleBob is offline
AF -Advisor
To enphasize what was suggested, yes, you need pressurized oil, but you also need to remove the oil from the turbo, and it requires a lot of attention. If you are using gravity drain (turbo is higher than the oil pan) you must use a large drain hose, with no odd bends, turns, angles and keep it as free flowing as possible. If you are not careful about this, the oil will back up and run into the turbine/compressor housings, causing the car to smoke like a banshee.
If the turbo is below/same level as the oil pan, you will have to use a pump to scavenge the turbo oil back to the engine, or you will get teh same results as above.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-11-2006, 04:08 PM
Ha, you just gave me the way to fix my truck with the turbos mounted on too much of an angle. I never thought of a scavenge pump. Wonder why none of my freinds ever suggested it? Oh well, thanks for that, no more smoking, restricted oil lines, and worn out turbos. I may actually re-install them.
Old 07-13-2006, 09:36 PM
Bob, maybe you can help me with info. I remember the max angle of the turbo shaft being 15 deg slope. Mine were a bit more angled than that. Do you think that with a scavange pump a turbo could be mounted on a much more of an angle?
Old 07-13-2006, 10:47 PM
AF -Advisor
maybe....can't say I've ever experimented with that. If it was a positive displacement scavenge pump that was very carefully sized/restriced to get the right ratio.....you could probably mount the turbo upside down if you wanted to.....but knowing that you have the right ratio is rather difficult
I'm almost afraid to ask why you "had" to mount it like that.....
Old 07-14-2006, 12:15 PM
It was just easier for clearance and plumbing, I didn't know at the time the shafts had to be on a more level plane. Thier not too bad really maybe about 25 deg angled towards the exhaust outlet and they smoked and wore out after I restricted the oil going into them (to get rid of the smoking) I found out later they should be level, I should've known. Using a scavenge will keep me from having to hack the flanges off the exhaust manifold and then haveing to replumb every connection on the trubo.
Old 07-14-2006, 01:47 PM
AF -Advisor
if it was me, I'd just fix the angle issue. Would cost a lot less. scavenge pumps ain't cheap. Adds complexity to the system that isn't necessary. If the pump fails on you, you can't drive the car.....something to think about.
Old 07-15-2006, 12:44 AM
Ok, thanks. I think the set-up may just set under the bench until I get the ambition to cut and reweld flanges and remount everything. Using nat aspiration is hard after being boosted for many years,,
