Old 07-09-2006, 10:24 PM
hcivic hcivic is offline
timing with new cam
Does the factory timing setting change if you put a bigger cam in?
Old 07-10-2006, 06:21 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: timing with new cam
I am going say no for now but what Cam and engine are we talking about here?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 07-10-2006, 08:22 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
what type of motor r u talking about? But to answer u in most cases it does, because of different lobe sep, duration, and intake centerline of the cam the timing also changes. unless the cam is just a bit over stock.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 07-10-2006, 10:29 PM
The car is a 87 camaro 305 tpi. Not sure of cam size its my buddy's car. I'll have to check. I know its a comp cam from summit racing.
Old 07-10-2006, 10:31 PM
FormulaLT1's Avatar
Fight the powwa!!!
I would say most cams for that set up minus some big ones that will require other mods. You will find that most TPI cams don't require advancing or retarding the timing from the stock.
Old 07-12-2006, 09:40 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
bumping the timing some usually does give noticable gains. I noticed that on my car. To my understanding there really isnt a right setting. It varried motor to motor as to which is the best. But the only way to know is to hook up diagnostic software and watch it. Just set the timing to stock and mess around with bumping it up about 2 degrees at a time. NO MORE! And see what works best for you. And remember just because you can hear the ping doesnt mean its not there so take it easy.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
