Old 07-09-2006, 08:55 PM
Demolition Man Demolition Man is offline
Third Brake Light
I have a 2000 Blazer 4dr. A few bulbs in my third brake light have gone out, how do I remove it to change my broken bulbs? Thanks.
Old 07-10-2006, 08:05 PM
muddog321 muddog321 is offline
AF -Advisor
Re: Third Brake Light
LEDs so whole light bar replaced - unless someone has soldered ones in out there.
Old 07-10-2006, 08:26 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You have to replace the whole bar, you can't replace individual LEDs.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-12-2006, 06:59 PM
goser goser is offline
Maybe the 2000 is different, but I pulled my 98 apart over dinner, cause I also have two blown LED's. Two screws in the top pop out and then the ends pull off and the circuit board slides out. Presumably you could solder in new LED's if you could find the right replacements, but all I can tell you so far is that they're clear lensed LED's arranged in 5 arrays of 6 parallel diodes.
Old 07-13-2006, 11:16 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I had to replace it and called 5 different places, dealer only item I was told. Cost me $125!!!!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 07-13-2006, 12:05 PM
BlazerLT's Avatar
AF -Advisor
I would check ebay.
Old 07-13-2006, 01:01 PM
$125 bucks!! Wow! Okay, I'm not going to get around to this for a while, so if you really want those LED's replaced pop off the unit and (with the brake pedal depressed) measure the voltage across any one LED. It should be around 2.7 volts. Then remove the burned out diodes and take them to your friendly neighborhood electronics supply store and get them to match it up with one that will handle whatever that voltage you measured was. Solder them back in (observing proper polarity) and you've fixed it for $1-2/LED.
Old 07-13-2006, 01:07 PM
BlazerLT's Avatar
AF -Advisor
http://cgi.ebay.com/ebaymotors/95-04...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/2001-...spagenameZWD1V
Also, this kewl decal:
http://cgi.ebay.com/ebaymotors/95-01...spagenameZWDVW
Old 07-13-2006, 01:23 PM
Sweeeet! I gotta make one of those for my Jimmy!
