Old 07-09-2006, 08:51 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
transmisson problem
i have a 1990 civic dx witch i just put a 1.6 zc into to replace the oil burner 1.5 it had. had the car together for a day ran great very happy with the result of the swap but as i was pulling out of the car wash or care wash as it was i heard a pop and she no longer moved. at first i thought it was the clutch cable witch has broke before on me and sounded simalr but no the cables fine. the car has no movment in any gear and if i step on the gas the spedo goes up as the car sits. the only thing that happens is when i put it in reverse i get a slight whiring noise.never had a problem with the tranny before and the clutch is new and flywheel was reworked. it is the stock dx tranny but it was pefect up till about 1 o'clock today. sound like anything simple or am i boned on this one dont have the money to get new tranny so most likely have to stick with this one for a while.as usual any help would be freakin sweet
Old 07-09-2006, 10:46 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: transmisson problem
Check your axles, you could have snapped one of them. Your transmission is obviously turning, so the clutch is good, and everything up until the speedo drive is turning, check to see if your axles turn.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-12-2006, 10:13 PM
yeah turned out i had just poped a cv shaft out of the tranny poped it back in and is fine found i had bad lower ball joint though
