Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 07-09-2006, 08:38 PM
jslubar jslubar is offline
2001 durango coling fan
2001 durango 4.7 - electric cooling fan quit - relays good - fuses good - is there a temp control to check? new dodge fan over 300 dollars - any ideas for replacement w/aftermarket fan?
Old 07-10-2006, 12:33 PM
jdq jdq is offline
Re: 2001 durango coling fan
May be a resistor check into a search on this, they are not expensive and can be a problem
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 07-11-2006, 04:56 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
If this is a single fan motor there should be a connector that you can unplug near the fan motor. Place 12volts on one pin and a ground on the other, if the fan doesnt spin then you know the motor is bad. Sometimes you can get just the motor brand new...call around to some of the bigger auto parts stores. If not, get a good used one from www.car-part.com
Maybe here...
http://www.autoparts-autoparts.com/d...densers_6.html
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 07-17-2006, 05:05 PM
steelerguy steelerguy is offline
If it's like my 1999 5.9, there is a plug behind the glove box that you can easily disconnect. The voltage check in Haynes was not like the actual readings but it did prove to me that the fan was bad. Found one at Carquest for less than $50 that seems a little better than the original.
If it's a resistor module, it will still work at full speed setting but probably nothing else. Again, this assumes the same setup as my 1999 5.9.
Changing the fan motor is a nightmare on mine. It took like 13 hours & every cuss word I ever heard got uttered at least twice. Keep in mind that you are pulling the fan assembly, taking it apart & replacing the motor portion. My dash board had to be nearly removed to do this.
The dealership gave me a price of like $900 just for the labor & they really didn't want to do it because of how hard it was.
