Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-09-2006, 06:07 PM
smoraq smoraq is offline
OBD 11 Failed to link & Blown Fuse
1994 Olds 88 (OBD11 sticker under hood).
Autozone attempts to read code; "failed to link" appears on screen. Cigarette lighter fuse is blown. Replaced fuse, lighter works during several attempts then blows again. Any ideas? (Car stalls often, cold or hot.)
Thanks very much.......Bob
Old 07-09-2006, 09:01 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: OBD 11 Failed to link & Blown Fuse
There were a couple of years of overlap on the OBD systems. If I remember right, some OBD2 systems were fitted with an OBD1 plug. This may have caused your reader to not work and may have connected a couple pins that weren't supposed to be connected.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 07-09-2006, 10:01 PM
Thanks for the reply, however, as the OBD 11 label is in the engine compartment, does that not necessarily mean that I have in fact OBD 11. The connector is 16 pin. What do you think? Thanks again, Bob
Old 07-10-2006, 12:19 AM
Alibi's Avatar
Ah...under the hood sticker. I didn't think of that when I wrote the last post. Hmm... I know this issue came up a while back in one of the forums. I'll try to find the link.
-Eric
Old 07-10-2006, 03:37 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: OBD 11 Failed to link & Blown Fuse
Find the cause of the blown fuse or no scanner will work, you need a " real" scanner to access the early obd11 cars, not Autozone.
Old 07-10-2006, 03:53 PM
OK, fixed the fuse issue. Now if the Actron scanner from Autozone won't pull the codes, can you advise which one will? Thanks again. a
Old 07-10-2006, 07:26 PM
A990 racer
Actron 9145 should, Snap on mt 2500, and all highline professional scanners.
Old 07-10-2006, 07:41 PM
Thanks. Hopefully someone else might have the solution.
