Old 07-09-2006, 04:58 PM
JCordone JCordone is offline
2003 Cavalier AC Problem
I have an 03 Cavalier with an AC problem and I'm hoping one of you can advise me. The AC wasn't coming out cool at all so I took it to the dealer.
He flushed it, filled it and added dye. He told me he saw no leaks, but the system was almost empty when he started the job, so there may be a leak somewhere.
Anyway here's the problem. When the car is moving, the AC works fine, but when its stopped and idiling, it blows out warm. Even with it on max ac setting. Nice and cool when the car is moving along, but as soon as I stop at a light or something, no AC.
Any ideas on what would cause this?
Thank you all for your time and advice!
Old 07-09-2006, 06:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2003 Cavalier AC Problem
You need to take it back and get him to recheck it.
It could have leaked back down or it may have a rad fan cooling fan problem.
A pressure gauge test of low and high side will tell him if it is low on r-134 and or if the system is working and cooling right.
If it has leaked out/down with the dye that was added the dealer can find the leak easy.
In the mean time take a look at the rad fan and see if it is working good and no rad air blokage and make sure the engine is not running hot.
Good luck and let us know how it goes.
MT
MT
Old 08-10-2009, 07:53 PM
kaptnhowdy kaptnhowdy is offline
check your radiator fan, if it is not working and you come to a stop, it will blow hot air.
Old 08-11-2009, 08:26 AM
MT-2500's Avatar
AF - Advisor
Welcome to AF
Always check the date on a post and if it is old and dead let it stay old and dead.
MT
Old 08-25-2009, 07:43 PM
alejandrodavila22 alejandrodavila22 is offline
would the compressor be a reason why the fan is not working?
Old 08-29-2009, 01:24 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Originally Posted by MT-2500 View Post
Welcome to AF
I think this is the first time I've seen someone posting after being told that a thread was old. Start a new thread and I'll be glad to answer your question.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
