Old 07-09-2006, 12:30 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Laptop keeps rebooting itself
I have an emachines M6805 with the athlon 64 bit. It was very nice at the beginning but all it's given me for a WHILE now is nightmares. The fan kept breaking inside and the system shuts off, I sent it in twice already to get replaced and it's still happening. Emachines, what do you make your computers with???
The problem I have now has stumped me, my laptop (only today) keeps going to the 'computer not shutdown properly' screen where it counts down from around 20 and you make a choice of normal mode, LWKG config or safe modes. No matter what I click or if I wait it out, it goes to the windows loading screen, then a very quick blue screen flashes and it reboots itself.
Does anyone know what's wrong, has this happened to you before? I want to get my files onto an external HD, is there a way to do it or pull out the HD and dock that somewhere? where, what hardware do I need to do that? Thanks in advance. I'm probably buying a new desktop now.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 07-09-2006, 04:55 PM
Quickshift Quickshift is offline
Send a message via AIM to Quickshift
Re: Laptop keeps rebooting itself
You could remove the harddrive and connect it to another computer as a 2nd hard drive and copy the files.
Old 07-09-2006, 06:59 PM
Dyno247365's Avatar
I was told I need a special adapter for this. Do you know what adapter I need?
Old 07-09-2006, 07:16 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
You might want to find out what is causing the rebooting, it might be viral.
Old 07-09-2006, 08:21 PM
Dyno247365's Avatar
Okay, ...how do I find that out? That's why I'm asking here to see if anyone knew.
Old 07-09-2006, 09:06 PM
Dyno247365's Avatar
I studied that quick flashing blue screen very closely
UNMOUNTABLE_BOOT_VOLUME
Old 07-09-2006, 10:09 PM
Moppie's Avatar
Master Connector
Thats a HDD failure
Nah, it might not be that bad, have a look here:
http://www.google.co.nz/search?hl=en...e+Search&meta=
If you can read the rest of the error code, and get the last two digits of the number it will help you narrow it down even more.
Old 07-09-2006, 10:18 PM
Dyno247365's Avatar
I need to make a windows XP boot disk. I don't have one.
Old 07-09-2006, 10:31 PM
Moppie's Avatar
Master Connector
If you have windoz XP on the PC your useing now, you can make one.
Old 07-10-2006, 03:47 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Mate I hate to say it but it sounds like what you want to do is beyong your technical abilities - I suggest taking it to a PC shop to image your data off ASAP.
You can get a laptop drive to USB converter, then plug it into the USB port of another computer and image data off, but it could already be toast, in fact that's a likely scenario. Leave it to the experts.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 07-15-2006, 05:10 PM
Dyno247365's Avatar
The only problem I see is the boot ini file is messed up. What I'm doing is trying to transfer my files to my external harddrive. Just because it's beyond my my abilities doesn't mean I can't learn how to do it. Yes there's XP on this system.
Old 07-15-2006, 06:29 PM
Dyno247365's Avatar
LOOK AT THAT. Someone actually bought XP before in my family so I used that disc and typed chkdsk /r. It's working it's magic so to speak right now.
Old 07-17-2006, 11:05 AM
harrymay harrymay is offline
You may have a corrupted disk, bad clusters, or a bad controller.
First thing I suggest is to wipe the computer clean. (Of course do a backup first, that computer has a DVD burner) Then I would format the disk. Re-install windows, and see what happens. Doing the chkdsk /r will work to get you back up and running. But I would go this route to make sure it doesn't happen for a while.
Mooninites Unite! Quad Laser!!!
