Old 07-09-2006, 11:09 AM
Slicer280's Avatar
Slicer280 Slicer280 is offline
Angry 97 Silverado
I don't use the truck that much, probably twice a month. Today I turned on the air conditioning and it just blew hot air. Last month it worked fine. I looked and it seemed like the compressor never ingaged. I checked the fuses and the 1 -10 amp is ok. Could it be the relay in the fuse box that is labeled A/C/? or is there another common problem.
Txs
Doug
Old 07-09-2006, 11:31 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 Silverado
Txs
Doug
First check would be for low freon and ac\heater controls.
Does the control panel work good? Blower motor and switching from heat to air ?
To check for low freon you will need a air cond recharge gauge set with low and high gauges like this
http://www.ackits.com/merchant2/merc...uct_Code=66773
Hook up the gauges and jump the compreser to run and give us your low and high reading at idle and at 2000 RPM
Also a good scanner will tell you if the air cond is getting a air cond request from VCM or control panel and sometimes the freon pressure.
MT
