Engine Hesitation At Constant Speed
1998 3.5 Intrigue. ~125K miles
For some time now, the car seems to jitter or hesitate when going uphill at a constant speed. Happens when in cruise control or not in cruise control. Jitter feels like it is going to shift gears, but doesn't. If going uphill and giving it gas to accelerate, there is no hesitation or engine jitter. Doesn't matter if the engine is cold or hot. Have OBD II reader and have not codes or console lights. Has anyone else expierience this problem?? Maybe it is normal for this car. Thanks. |
Re: Engine Hesitation At Constant Speed
The problem is not normal. It sounds like you are experiencing what is known as "chuggle" or "fishbite". It is the torque convertor locking and unlocking and shows up while the car is under some sort of load.
It can be caused by an ignition related problem such as spark plugs (misfire), fuel delivery problem or worse case a problem with the 4T65E tranny such as the TCC solenoid.
How would I check some of these issues out? I have a OBD II reader and do not see any codes during the times of "fishbite".
If it was misfiring, I thought it would display an error code? As for the fuel delivery concern, would I need to take it to a shop to check the fuel line pressure? I know the fuel filter has been replaced a few times already - just regular maintenance stuff. Also, for the transmission, I would definitely need to take it in to have an experienced professional look at it. Could they simply replace the TCC Solenoid or would the entire transmission need to be replaced or rebuilt? Thanks for your assistance.. |
You're welcome and good luck!
My 99 3.5 was doing something similar. Very occasional, long time between. Eventually a P0300 code was set (not helpful). Search for that code, you'll see the thread.
It seems to have been fixed by replacing the MAF (easy to test, disconnect the MAF harness for a while). |
