Old 07-08-2006, 08:00 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
mass air swap
i'm doing a mass air swap and right now i have a A9L computer and the engine harness out or a 89 mustang. i was wondering if i can use a 76 mm mass air meter calibrated for 24 lbs injectors with the A9l computer?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 07-08-2006, 08:03 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: mass air swap
As long as you have 24# injectors to go with that harness you will be fine.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-08-2006, 08:57 PM
Re: mass air swap
ok good i'm trying to think ahead for future mods.
