Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 07-08-2006, 06:53 PM
Phil0968 Phil0968 is offline
Send a message via AIM to Phil0968
Loose Rear End
The back end of my 93 J30 has begun to give me a couplle scares. Anytime i go over any kind of bump on the road my rear end feels like its going to slide sideways, typically feels like its sliding to the right. Any ideas where i can try and find the problem behind this. I'm not sure if its a rear strut issue or maybe a problem with my shocks, any help would be greatly appreciated.
Old 07-09-2006, 04:13 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
Re: Loose Rear End
check your rear struts for oil leaks if oily shockies need replacing
bounce on rear end then jump off see how long it takes to stop bouncing should stop almost imediatly if not shockies need replacing
Old 07-09-2006, 04:33 AM
Re: Loose Rear End
[quote=sparkeykev]check your rear struts for oil leaks if oily shockies need replacing
bounce on rear end then jump off see how long it takes to stop bouncing should stop almost imediatly if not shockies need replacing[/QUO
My back end does not continuously bounce up and down, so im assuming my shocks are not the problem, im thinking either an alignment issue or a problem with one of my rear struts
