Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-08-2006, 05:00 PM
michelin michelin is offline
fan switch not working on setting 1 and 2
on 00 impala..i thought it was bad switch so i bid on ebay and won it so replace it whole new same thing not working on setting 1 and 2 ,work fine on 3,4 and 5. i wonder what cause it...hope u can help thank you
Old 07-08-2006, 05:55 PM
ogre73 ogre73 is offline
Re: fan switch not working on setting 1 and 2
It's quite a common problem. It is a resistor in the blower motor. An easy and cheap fix if you know how to solder. Do a search for more info.
Ogre
Old 07-08-2006, 06:25 PM
ok mine is climate control switch..and where is the locate of blower and where do i get the parts for it do they have website ,explain how to fix thank you
Old 07-09-2006, 10:24 AM
Search. If you search on here, you will find the information. It would take me longer to do the search for you, copy the links, paste them, and write a cordial reply than it would for you to use the search button.
Ogre
