Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-08-2006, 04:10 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
1g throttle body -help-
i finally got the motor back together but the issue im having now is that my turbo throttle body is pretty much junk and im having a hard time finding a new one for a decent price, my question is that i got a 1g 4g63 n/t throttle body thats completly rebuilt. Is there any way i can get it to work?
Old 07-08-2006, 05:59 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 1g throttle body -help-
Yes it can be made to work with a few modifications. I have an extra 90 turbo TB if your interested in just buying that. All you would have to do is put your TPS on it... Yours is a 90 right?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-08-2006, 08:08 PM
my car is a 92 but the engine is from a 1990 tsi awd, ecu is a 1992 fwd turbo ecu,
Old 07-08-2006, 08:10 PM
what mods do i got to make to make the NT TB work on my turbo manifold ?and how do i make the elbow fit, can you send me to a write up on this, or maybe some pic's would be great.
Old 07-08-2006, 08:16 PM
I think all you have to do is the EGR blockoff plate and block off some of the vaccum lines... I would just get a 90 degree elbow that will fit it instead of trying to modify the one you have. Also, what year is the n/t tb from? The 90 ones had a different TPS than other years. If the n/t tb is from a different year then you will need the TPS from that year (if its not already on it) and then hardwire it into your wiring harness. Sorry I don't have a writeup on it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-08-2006, 10:17 PM
can you give me all the info you know on doing this, like all the things i need and what i will have to do to make this work, thanks man
Old 07-08-2006, 10:19 PM
Well what year is the n/t TB from and does it have its TPS on it still? I need to know that before I can tell you what you need to do.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-09-2006, 04:00 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
You can't use a 1990 TB or TPS. The N/A TB are perfectly fine, you will have to live without a tb-elbow due to the lip on the n/a. The opening on the n/a is a little over 60mm though it tapers down to 60mm at the butterfly. The TPS, ISC are both the same between turbo & n/a cars. It is recomended to replace the tb seal on a n/a, you can find that on Vfaq.com.
DSM geek
Old 07-09-2006, 02:14 PM
kjewer1 kjewer1 is offline
AF - Advisor
To clarify, it depends on the wiring harness. The fact that you have a 90 motor is meaningless. A car with a 91-99 wiring harness can use 91-99 turbo TBs, and NT TBs, though I thought only the ones from the 2.0 are worth using. Can't guarantee that one from a 1.8 will work. The NT TBs require turbo TB shaft seals to be swapped in. I don't think that modifying the UICP to work with a NT TB is worth the time and effort at all, just swap the ISC and FIAV subassembly over assuming the basic TB itself is ok (plate or shaft is not bent, etc).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-10-2006, 01:40 PM
ok sweet thanks
