Old 07-08-2006, 11:41 AM
jasonb01 jasonb01 is offline
Adding Power Seats
I have the chance to pick up a set of power front seats for my truck. Neither one of mine now are power. Would I just need to run a 12v source from the fuse panel or somewhere to feed them, or is there more or less to it? Truck is a 2000 ECSB. Thanks
Old 07-08-2006, 10:17 PM
ColoradoSilverado ColoradoSilverado is offline
Re: Adding Power Seats
Someone explain to me why someone needs power seats....
Bert
Old 07-08-2006, 11:20 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Bert
I tell ya Bert, I'd sure appreciate being able to move the front portion of the seat vertically up a little bit on long drives. At least, my ass would! Power part of it is just another thing to break, true enough, but man, I'd love the extra degrees of freedom.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 07-09-2006, 01:23 AM
Unhappy Re: Adding Power Seats
Boy that was a lot of help with my question. Thanks. Since noone wants to answer my question, I guess I'll answer yours. Nooone needs power seats, but my seats are worn and ripped, at least the drivers side is, and I found a power set for cheaper than I can find a manual set for. So why not? No, I don't need them, but they would be more comfortable then my old ones.
Old 07-09-2006, 11:52 AM
Elbert Elbert is offline
Yes I think so... you just need to provide a12v power to the seats using the appropriate size wire. I don't recal anything special about power seats. I would make sure to get all the parts with the seats though. Yoy may have to provide a ground too.
Old 07-12-2006, 01:03 PM
Bill-SILV Bill-SILV is offline
I think the wiring is already ran to the seat isnt it?
Old 07-12-2006, 03:28 PM
guumbah's Avatar
guumbah guumbah is offline
My ass and lower back appreciate it even on my daily commute! NEED? no. ENJOY? yeeessss.
I'm not sure if the non-power seated trucks are pre-wired (never looked at one to see) but you should be able to tell. I have definitely heard of people paying extra to have dealerships swap them out so they can get a particular exterior color they wanted, but I don't know what it entailed. If I remember right, the wires come out of the carpet on the side closest to the center, at the back. I'm at work right now, and parked WAY too far away to run out and look, but I can check later. Take a look at yours around that area, and you can probably feel if there's a harness under the carpet right there, or even better a small hole to pull one through. It's not like they are computer controlled or anything, so I doubt it's more complicated than providing power and ground if it's not already there.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
Old 07-12-2006, 07:27 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I don't have power seats, but I can't raise and lower the front part of my seat. You should have a lever on the right side next to the center console.
*Under Construction - New sig to debut*
