Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 07-08-2006, 10:50 AM
jeev155 jeev155 is offline
Deck Install - how important iS GROUND
Hey, i recently tried to isntall a high-powered deck. it powered up, but when i tried to put the cd in, the power kept lagging and shut off [ on the deck ].
I noticed that i did not have the ground properly grounded. could that have caused the power to lagg [ there is a fuse on the ground wire of the deck that i think might have blown? ]
Old 07-08-2006, 12:15 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Re: Deck Install - how important iS GROUND
If you don't have your equipment properly grounded it will not hesitate to malfunction. I had a stereo system hooked up but the ground wasn't right and I kept blowing fuses in my power wire from the battery. At first I thought I needed a fuse with higher resistance, put one in and it melted the damn thing
But before the fuses would blow, my amp would overheat. It'd work fine for a while then cut out for a few seconds at a time. Then it'd cut out for a minute. Then it would overheat and shut itself off til I unhooked the power wire. So I in=magine this is whats going on with your deck on a much smaller power scale (300 watts vs 2,400)
ECNATSISER AL AVIV
