Old 07-08-2006, 09:18 AM
MakeItADouble's Avatar
MakeItADouble MakeItADouble is offline
Bosch?
I bought some bosch plugs for my 98 GMC jimmy V6. I've been reading around here that AC Delco's are better. Whats so bad about the bosch??? Should I return them and get the Delcos?
Also plug wires. What brand do you gear heads reccomend?
Thank you in advance.
Old 07-08-2006, 01:51 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Re: Bosch?
Do a search on spark plugs and go from there. Everyone has a different opinion on the wires but the majority of people here do recommend Delco plugs just because they match up better with our trucks.
But like I said do a search and read some of the posts and make your choice from there.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 07-08-2006, 02:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Bosch?
If you love your blazer do not even let a bosch plug within a mile of it.
The only good place for them is in the trash can.
They will not run right or very long in a GM engine.
Fire up that search engine and check around.
Take them back and tell them you want the AC-delco spark plugs that the good book calls for.
As far as plug wires get the best ones.
When the ask you if you want cheap or a little better or the best tell them you want the best and the one that meets OEM quality specs.
MT
