HAY
I have jimmy 1998 I have sometimes problem When i push the speed pedal i hear some noise like some aluminium moving, and after 2-3 minuts is ok This is only when i am driving, and hapened every day more I check under for some aluminium losses or something, an i cant found anuthing THANKS |
Re: Noise
Give a little more info please...
Is the truck 4wd? Where does the sound come from...front? back? left/right side? Is it a scraping or rattling sound? Or a clunk? Does it happen only during certain times? accelerating? braking? turning left or right? Anwswering these can help pin down what might be going on...thanks!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
ok
This sound omly when i am acelerating, and after gone is lokes like some losse metal, or likes when you turn some papers araund is caming from under the car its maybe some paper or something on the cardans the jimmy is 4 wd is likes tkkkkkkkkkkkkkkkkkk thanks |
Re: Noise
My first guess would have to do with your 4wd. Check to make sure that the tranfer case is disengaging completly and that the front differential is disengaging. What can happen is that the vacuum lines that lock the front hubs can develop a hole and not allow the front differential to lock the front hubs completely, causing a slight noise where the meshing gear teeth just barely touch each other. But for that to happen, the transfer case would have to be engaged. This can be caused by a stuck shift cable for the manual (floor) shift like mine, or by a bad shifter motor for the push-button type. If you have a good floor jack and four stands you can check engagement by lifting the whole truck (no tires touching) off of the ground, starting the engine, and putting it in gear. UNLESS YOU ARE AN EXPERIENCED MECHANIC, DO NOT TRY THIS...IT IS DANGEROUS! Improper placement of the jacks can cause the truck to fall and move under uncontrolled power. Go to your friendly mechanic and have them check the 4wd for proper engage/disengagement.
Other unrelated causes might be a loose heat shield, a front or rear differential that is low in gear oil, or failing axle bearings. Good luck!
THANKS
I go to the diler and they fiksed Wase the U yoing bad 160 dolars and now its OK THANKS |
