Old 07-07-2006, 10:25 PM
mummy3 mummy3 is offline
Exclamation 03 EXT Rattling and Clanking!!
I have a severe rattle / clanking from the rear of my 03 Trailblazer ext. It sounds as if the bottom of the truck is loose and it happens whenever I drive over the slightest bump, rock, etc... I have taken it into the dealer. They have confirmed the noise but tell me everything checks out okay. Including the sway bars.
Another tech ( who has not heard nor seen my car ) told me it WAS the sway bars and that it was a very common problem with the Trailblazer.
I don't know what to do.... Other than driving around with my windows closed so I don't hear it as loud as those outside of my car.
I did see there was a service alert for rattling/clanking in the Trailblazer and I brought it to my dealer.... He said they can't find anything wrong.
They won't find the problem until I go to trade it in for another truck ...Then they'll tell me it needs to be fixed.
Tell me... someone else has to have this same problem!
Old 07-07-2006, 10:41 PM
rodeo02 rodeo02 is offline
Re: 03 EXT Rattling and Clanking!!
Bad stablizer bar (sway bar) end links. Very common, lots of posts on it. New end links will solve this.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 07-07-2006, 11:02 PM
So ... What's up with a chevy dealer that says the sway bars are fine? I'm tired of paying for their "time" only to be told there's nothing wrong.
Old 07-08-2006, 10:20 AM
The sway/stablizer bars ARE fine. It's the end-links that are bad. They are attached to the bar towards each wheel and are technically a seperate component from the sway bar. Your GM dealer sounds like your typical knuckleheads.
Joel
Old 07-30-2006, 06:56 PM
fastco's Avatar
fastco fastco is offline
See this thread for part numbers and stuff if you need the sway bar end links. What a difference new ones make!!
http://www.automotiveforums.com/vbul...d.php?t=581254
SC
WWW.geocities.com/techsolutions
