Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-07-2006, 06:50 PM
crj_lll crj_lll is offline
Send a message via AIM to crj_lll Send a message via MSN to crj_lll
Irregular engin activities and engine codes
Can anyone help me with this?
For a few years now my car, a 97 dodge neon, has been doing 3 strange things.
- In summer it tends to overheat if the A/C is above level one when driving around town or up small hills.
- the check engine light comes on periodically, and when the key code is checked it says the issue is the oxygen sensor.
- the engine often revs oddly when parked or stopped, like when first turning it on or when stopped at a stoplight. When it is really bad, it bucks when driving sometimes when windy. But it hasn't done that in a while. It usually just revs really high and then sounds like it is about to cut out. It doesn't cut out, but sounds like it.
When I took the car in last for this problem (9/04), they wrote the following: "Check engine light on, idle fluctuates when at idle. Performed scan test. Code P0132, oxygen sensor shorted to voltage and P0134 oxygen sensor stays at center. Ran diagnostic, traced codes to faulty oxygen sensor and replaced with new part. Cleared codes and road tested. Idle is consistent now, idle concern may have been caused by bad oxygen sensor."
And life was good for a few months. Perfect. Lovely. Later that next spring, the check engine light was on again, it was starting to idly a bit oddly again, so I took it in. They checked it (check engine light had turned itself off by then) and told me to make sure the gas cap was closed securely and that it causes a lot of problems. It sounded strange since I always twist the gas cap two or three clicks as habit.
Any help would be greatly appreciated.
Old 07-07-2006, 06:57 PM
jd-autotech jd-autotech is offline
Re: Irregular engin activities and engine codes
look at your coolant its probably brown sludge due to the blown head gasket i see that one all the time on the neons the engine light is probably not related.
Old 07-07-2006, 07:24 PM
If the head gasket is blown, would the factory tech have seen that and also wouldn't I have a cloud of white smoke following the car as it is driving down the road?
Old 07-07-2006, 09:15 PM
HPNOTIQracing HPNOTIQracing is offline
you have 2 o2 sensors the other may be bad now
Old 07-08-2006, 09:50 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Generally it's the upstream sensor.
Old 07-08-2006, 11:18 AM
my down is bad right now.
Old 07-08-2006, 04:19 PM
What is that and where is it located? How much from the dealership?
Your down? Are you saying there is a down stream also?
Old 07-08-2006, 05:46 PM
Upstream is on the exhaust manifold and down is after the cat converter.
Old 07-08-2006, 08:12 PM
yep 2 of them som bitches
Old 07-09-2006, 04:28 AM
FemaleRacer FemaleRacer is offline
Not necissarily. I blew a head gasket and didn't have white smoke. And the DEALERSHIP missed it. I realised the problem when i was replacing the spark plugs and noticed the oil. (and on a side note-it's bizare that the spark plug tubes are SO long in a Neon)
Also-running on a bad o2 sensor can do quite a bit of damage to your cars engine. Especially if you drive it frequently in stop and go traffic. I've been told that especially with Neons it's good to hit the freeway and blow some of that crap out of your engine. I don't know if that's really factual---but hey-it does give me a guilt free reason to take it to 75 on the freeway every now and then
Have you ever had a shop to or mention a need for an engine vac?
Don't let the 34JJ's and 6" heels throw you off...I race to win. No games. Just you in my rearview mirror
Old 07-09-2006, 04:02 PM
Thanks, I will check for the blown head gasket as well.
Old 07-11-2006, 05:41 PM
running no or bad 02's wont hurt your car. thats why mpp com and afx coms bypass them all togather. i left mine hangin there on my last r/t when i got my mpp com and full exhaust. the SENSOR is there to tell you any erregularities with you air/fuel mixture by kicking on the dummy light. the neons computer is designed to correct any of the air fuel issues on its own.(for the most part) it just senses when there is an issue so if there isnt an issue with your air/fuel you can bounce the sensor down the street.
now someone is proly gonna come on here and tell me that the computer uses the readings from the o2's to make the corrections to the a/f but i have personally learned that it will run just fine without the sensors.
but im not promoting it im just giving another point of view.
Old 07-19-2006, 11:30 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
the irregular idle could be due to a vacum leak or a dieing forget what its called sensor it right next to your tps sensor and has the plunger on it
