Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-07-2006, 05:25 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Compression test results...
So, a few of you may know my car has been having this wierd overheating problem for a few days now. I still have a pinched lower radiator hose and I ordered the part but, I decided to buy a compression tester and I just got done using it. I have heard using like a teaspoon of oil when you do it but, I did not because, I was not sure about it. Anyway here are the results, they were all pretty consistant. From left to right it reads. 150-140-130-145 Any input on my situation?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 07-07-2006, 05:33 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Compression test results...
You've got a problem and you shoudl fix it before you run it much more. You arent supposed to be more than 15psi difference, you've got 20. My $20 says you have a blown headgasket.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-07-2006, 06:09 PM
NateS's Avatar
Yeah, I haven't been willing to admit that I have a blown headgasket. I guess I can just face the facts now. I have been looking for a pos beater for a few days now. Think I will be okay to drive my car for a bit untill I get a beater? I haven't been driving it hard, just to work and back every weekday. Whenever my car starts to overheat I let it cool down then continue on my way. Hopefully I'll be okay because, I really don't have another way to work.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 07-07-2006, 06:51 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
You should be fine, just don't boost the shit out of it.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-07-2006, 07:10 PM
jd-autotech jd-autotech is offline
yepper blown head gasket, remember the first step in solving a problem is admitting you have one.
Old 07-07-2006, 07:26 PM
NateS's Avatar
Well the only reason I am admitting it now is because, I am thinking of taking advantage of having to remove the head or maybe trash it. (see off topic)
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 07-07-2006, 07:38 PM
Killa's Avatar
Killa Killa is offline
I boost around 10 psi every day, and about 5-7 psi every gear, is that normal for DD ?, thanks
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-07-2006, 07:53 PM
NateS's Avatar
I am not sure where your turbo starts to spool but, I ussually only push about 1-2 maybe 3 ,if I'm lucky, pounds of boost daily driving. I ussually don't even build boost, well not enough to read, when I am daily driving. I ussually shift around like 3.5k rpms. Depends on how you drive I guess. I try to baby it when I can because, I know an hour from then I will probably be beating the hell out of it.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 07-07-2006, 08:18 PM
Killa's Avatar
my turbo start to spool at 2.5k, and if I shift at 2.5k, the speed is not match, and the car kinda jerking , so I shift every 3k or 2.7k every gear, and my turbo boost around 5 psi when I shift that way.
GM FOR LIFE !!
95 camaro lt1
Old 07-07-2006, 08:57 PM
NateS's Avatar
How hard do you hit the throttle? I ussually don't stomp on it while daily driving. If you keep the throttle % real low you still accelerate(not as fast) and it can keep you from building boost or not as much. If you have a smaller turbo then it will probably boost pretty easily. It is not hard to tell if your beating your car or babying it. Best advice is be your own judge haha.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 07-07-2006, 09:57 PM
Killa's Avatar
I cant keep my foot off the gas , Im gonna take it easy tomorrow, I wont boost unless I need too.
GM FOR LIFE !!
95 camaro lt1
Old 07-07-2006, 11:26 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
LMAO man im sry but your babying the shit out of it!! i was running 18psi on my T-25. 10 psi is 3 to 4 psi below stock psi why the hell would you run so low?
Im not being a dick here im just being serious and speeking the truth.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 07-07-2006, 11:28 PM
Thor06's Avatar
Jizzed In My Pants
I think he means hes just revving it out until it gets to 10 psi, not necessarily meaning its at full boost at 10 psi.
Old 07-07-2006, 11:32 PM
Talon69's Avatar
Maybe, but im curious to here from him now
Current Cars
Old 07-08-2006, 12:11 AM
Killa's Avatar
yes some time I was thinking, I did babe the hell out of the turbo, some time I boost high 10-14 psi just wanna to heard how loud the bov sound ,
Most of you might know that, my ISC ( IAC ) is busted, and Im waiting for new one to come, and I know I should idle the car for couple min to let all the oil out off the turbo, my car idle like shit and 2.5k or 3k, so I turn off the car right away, when ever I finish drove the car, is that bad ?. How long should I idle after driving the car ? I got greddy turbo timer, and waiting for some one to install it for $100.
GM FOR LIFE !!
95 camaro lt1
