Old 07-07-2006, 02:51 PM
jay jay is offline
I want to do away with the efi and put a carburetor in
Here is the scoop I have an 89 chevy s10 with a 2.5 4cylinder efi. I want to do away with the efi and put a carburetor in it any help would be appreciated
Old 07-08-2006, 02:31 AM
OverBoardProject OverBoardProject is offline
Banned
Re: I want to do away with the efi and put a carburetor in
Welcome to Automotive Forums jay
Are you aware that the truck will never pass emisions in most states / provinces with a carburator?
If you are then no prob.
Never atemt to work on the fuel system without having a fire extinguisher handy.
Plus always disconect the battery and re-conect it only when there's no chance of fire happening.
The easiest thing to do for these first few steps is lift the box off.
You'll want to switch the fuel pickup in the tank to 1 made for a carburator (85 or older I believe)
Install a low pressure electric fuel pump beside the tank. I imagine that you can use the existing fuel pump wires.
I would install a cheap in-line fuel filter in here as well.
Now remove the inlake manifold and replace it with a carburated unit. Hook up all the cables, the fuel line and what not. You'll probably have to block the return fuel line off.
Try the key, and it should fire up. (don't forget that you dis-conected the battery)
If it does and seems to work right bolt the box back on and double check all your work.
Personally I'd just stick to the fuel injected system, it'll give you both more power and a little better fuel economy.
Old 07-09-2006, 06:05 AM
jay jay is offline
Sounds like i will be better off sticking with the efi Or putting a whole nother engine in
Old 07-09-2006, 09:01 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Pretty much. Also, carb is not as accurate as efi, so you gas miledge would certainly go down, which in this day and age, unless you have lots of disposable income is not a good thing.
