| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
![]() Join Date: Mar 2005
Dead gauges .... speed, gas and temp all read zero no matter what.
I lent my car to a friend who had it for the weekend ... when I got it back I noticed that the gauges weren't working. My friend said he doesn't know what happened.
We already checked all the fuses and replaced a few anyway with no results. Is this a computer problem or something a little simpler. speed, gas and temp all read zero no matter what. |
#2 | |
![]() Join Date: Dec 2005
Re: Dead gauges .... speed, gas and temp all read zero no matter what.
you need a new cluster. this is a very common problem
#3 | |
The cluster, does that mean the entire display panel? Will that change the milage readout on the car?
#4 | |
yes the whole instument cluster. its easy. pop the top of the dash of and there are i believe 2 screws holdin it in. now the 98 99 just pop onto the clips the earlier you have to pull the clips out of the back of the cluster.
yes that will change the mileage. if you get one from a junkyard it may have around the same miles. but there is now gauruntee it will work |
#5 | |
![]() Join Date: Jun 2005
try this , worked perfect for me when my guages stopped working...
http://www.neons.org/modules/news/ar...php?storyid=18
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt. |
#6 | |
Tuning Neons since '97
If the above post doesn't work for you, get a used cluster and swap in your odometer to keep your milage correct. It isn't difficult at all, just some T15 and T9 torx bits.
#7 | ||
![]() Join Date: Feb 2006
And I think the guys are right on---it's most likely your cluster....but hey at least it's one of the easier things to fix. |
