Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-07-2006, 11:30 AM
EricSchnabel EricSchnabel is offline
Boost
How many pounds of boost can you run on the 8.5:1 compression ratio before haveing to use above 91 octane.
Old 07-07-2006, 12:17 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Boost
you should always use 91 or above no matter how many psi you run, My car only drinks 93.5
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 07-07-2006, 12:41 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Boost
It all depends on your car and modifications. Do you have an upgraded fuel pump and injectors? do you have a way of controlling those injectors? What turbo are you running? you should have your mod list in your signature. we need a little more info before we can answer that.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-07-2006, 03:02 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Boost
8.5 isn't too high. I would say a few psi less than if you were on stock compression, but the only way to find out it to actually test it man. Most people that do it say it's completely worth it though.
now - 2000 civic
soon - 2002 is300
Old 07-07-2006, 06:25 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Boost
92-93 FTW. I wouldnt run anything less. $3 more per fill up is way cheaper than rebuilding your engine because you knocked like hell on 87.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-08-2006, 01:22 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Boost
Some areas only get up to 91 octane.
Unfortunately, it is completely impossible to answer the question in the original post. The only way to know how much max boost you can safely run is to datalog the car while raising boost and watching knock (and AFR if you can afford it).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-11-2006, 11:20 PM
george536's Avatar
george536 george536 is offline
Re: Boost
yea and thhat is cali for you, 91 is our premium n:
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
