Old 07-07-2006, 05:03 AM
Newbie600rr Newbie600rr is offline
No fuel pressure
My 95 blazer started to bog and loose power and then kick in again. After doing this a few times it started to stall out and now it wont start at all. I know I have a bad cpi and I have the parts to replace it but I have no fuel pressure at all. I pulled the filter and replaced it. the pump doesnt sound like it turns on when I turn the key. Any other problems other then a bad pump that would cause no pressure. and it does have gas.
Thanks
Old 07-07-2006, 05:55 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: No fuel pressure
Thanks
Well, if you know you have a bad CPI, your regulator could have comepletely blown..
Old 07-07-2006, 08:04 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
There may be better ways to do this but a quick way is to pull one side of the fuel filter off and point it into a coffee can while someone turns the key on, don't start the truck, just turn the key to the ON position. If you don't get any fuel pumping out into the can, your fuel pump is not getting power or is shot completely.
If you do get a steady stream of fuel, then you can eliminate the fuel pump as the culprit.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 07-07-2006, 08:14 PM
jsgold jsgold is offline
Just my two cents worth, I have lost two fuel pumps on my 93, very common problem. If you are going to have the truck long, invest a few bucks in a fuel pressure guage, and a good manual. You do have a fuel pump relay that can go bad, but this does not happen too often. You should be able to hear the pump kick on, or at least the relay clicking when you turn the key. Always can be other things such as a broken wire etc., but a guage is cheap, ditto on the manual.
I used to be indecisive, now I am not so sure.
Old 07-09-2006, 10:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks
Proper testing first.
Check for 12 volt voltage and ground and wiring to fuel pump.
If no run and it has voltage and ground replace it.
If it runs but not with the right amount of pressure replace it.
MT
MT
