Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 07-06-2006, 07:22 PM
stamptrain2 stamptrain2 is offline
Location of cruise module - 96 Jetta
Because the cruise control fails, I want to replace the module but I can't locate it. My Bentley manual says it's in the left 'A' pillar but all I can see is the fuse panel. If anyone has "been there done that", I would appreciate your help. Does the fuse panel have to come out to get to the cruise module?
Richard
Old 07-07-2006, 01:41 PM
Doug Tatham Doug Tatham is offline
Re: Location of cruise module - 96 Jetta
From my understanding of labeling, the left A piller should be to the left side of the dash under the trim in front of the door. The pillar is usually the part that supports the roof and goes down until you get to the floor. A is the front most, B is the one between the doors...
At any rate, it should be to the left of the dash rather than behind it.
Old 07-09-2006, 06:50 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
take out the "abs" light and headlight switch from the left dash. Its on top of the alarm module
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-10-2006, 02:21 PM
Thanks for the correction veedubmechanic. I try to help, but if it's a model that I'm not familiar with I have to guess. I'm a weekend mechanic only.
