Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-06-2006, 06:43 PM
gravyd gravyd is offline
1999 malibu
secondary air injection problem according to scanner (check engine light on)
pump not running, took off car, pump had water and a little oil in it. cleaned
it up put voltage to it and it worked. checked connection on car, no voltage to it. sounds like i'm getting some air back from the manifold once in awhile,
it comes and goes. could it be the check valve, or could the relay be bad ?
it's the air pump, not the water pump.
Old 07-10-2006, 03:36 PM
tractorboy's Avatar
tractorboy tractorboy is offline
Re: 1999 malibu
whoa .... pump, what pump, the water pump ? more than likely you have a lower intake manifold leak. Pull your dip stick and look at the oil. If there are signs of coolant in the oil, even small amounts, or large amounts , like the oil looks like chocolate milk. DO NOT DRIVE THE CAR. Collant in the oil will ruin your main bearings.
Old 07-11-2006, 08:48 AM
Re: 1999 malibu
sorry about not being clear about that.
