Old 07-06-2006, 06:36 PM
magnum3456's Avatar
magnum3456 magnum3456 is offline
Banned
squeeky brakes..again
A while back i couldnt get my brakes to stop squeeking while braking...so i got new rotors...that didnt help...so i went out and bought some ceramic brake pads from morse and they seemed to work for about a month or 2 and now theyre squeeking again...i replaced caliper pins and bushings also...what are some ideas as to why my brakes are squeeking...it ususally is the front right...but i think i heard my front left just today...ideas?
Old 07-06-2006, 09:00 PM
Cruize Cruize is offline
Re: squeeky brakes..again
Have you tried the anti-squeel schmutz from a parts store? I've never used it, so I don't know if it works or how well, but I'm gonna try it as soon as I get all my major work done.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 07-06-2006, 09:25 PM
magnum3456's Avatar
Banned
yep...sure did...lubed up the pins too real good...
Old 07-06-2006, 11:00 PM
Are there wear indicators that are set improperly?
On the pad, is there a groove running down the middle that separates the wearing surface into two areas? If so, is there an accumulation of dirt, stones, debris in there? I had brakes on a different car that made almost like a grinding noise once this groove filled with dirt.
Cruize
Old 07-07-2006, 05:04 AM
muddog321 muddog321 is offline
AF -Advisor
How are the metal shims in the brakets that the pads slide on - clean all rust etc from the bracket before installing the shim and then make sure the pads are loose enough and not jammed/locking in the bracket - if they are jamming and not free they will always rub and make noise - happens alot in salt use areas and 4wd from lots of dirt/mud getting in there. This is a 95 so rear drums - done them too lately?
Old 07-07-2006, 05:54 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
When you apply anti-squeall, you need to apply it to the back of the pads not the pins...
Old 07-07-2006, 02:07 PM
TheBrettster TheBrettster is offline
AF Premium User
glaze build up ?
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
