Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-06-2006, 06:18 PM
72 rs's Avatar
72 rs 72 rs is offline
head bolts ??
i have a 96 sohc neon with 120,000 miles and was wondering if i should replace the head bolts when i change my head gasket ?? the car also just recently started dying after about 20 min of running, kinda acts like its not getting any fuel or spark (dont know which i havent checked). when u let it sit for a min or two it trys to start( kinda sputters a lil) but dies if you take ur foot off the gas. head gasket related or do i need 2 look somewhere else??
87 chevy silvy
91 transam 700r4 and torque convt.
new comp.
hypertech chip
accell ign. cont. modual
dual electric fans
94 lt1 long tube headers
custom exhaust
flowmaster 40 series muff.
3-4 suspension drop
helix tbi spacer
k&n airfilter
custom built cold air intake
Old 07-07-2006, 07:49 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: head bolts ??
Yes, you need to change the bolts with new ones or they won't seal correctly.
The sputtering problem could be gas, plugs and/or wires. Is your CEL on?
Old 07-09-2006, 07:50 PM
72 rs's Avatar
Re: head bolts ??
come and goes when it wants. when it does come on its telling me missfire on cyl. 3
87 chevy silvy
new comp.
hypertech chip
dual electric fans
custom exhaust
3-4 suspension drop
helix tbi spacer
k&n airfilter
Old 07-10-2006, 08:21 AM
Re: head bolts ??
Have you changed your spark plugs with the stock champions and checked your wires and coil pack for cracks?
Old 07-13-2006, 06:57 PM
72 rs's Avatar
Re: head bolts ??
i just recently got the car from a freind ( free because of the head gasket) so im going off what she said and experianced.she had new plugs and wire put on it before she gave up on it. i only drove the car twice when i got it and it only did it the 2nd time (drove it about 15 min ). Right now its torn apart in my drive way waiting to be put back together, so i guess ill troubleshoot it more when the heads back on it.
87 chevy silvy
new comp.
hypertech chip
dual electric fans
custom exhaust
3-4 suspension drop
helix tbi spacer
k&n airfilter
Old 07-14-2006, 12:41 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: head bolts ??
Make sure you use new head bolts.
The bolts are of a stretch design and only stretch once.
If you re-use already stretched bolts they will either break or the head will loosen up enought to blow the head gasket within a few hundred miles.
