Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-06-2006, 05:54 PM
Cain98Eclipse Cain98Eclipse is offline
Send a message via AIM to Cain98Eclipse Send a message via MSN to Cain98Eclipse Send a message via Yahoo to Cain98Eclipse
Question Running water sound
When I am driving in first and second, I hear a sound of running water from my dash. What could this be? I thought it was the AC but I turned it off and I still hear it.
Another ? I recently primered my car (done a good job too) but my dash lights dont work and my cd player will not work either I have checked all the fuses and they are all good? Could this be my battery dying?
Thanks,
Cain
Car: 98 Eclipse RS NT
Mods:
AEM Cold Air Intake
Megan 4-1 header, downpipe, and testpipe.
Megan Cat-Back exhaust 2.5" with 4.5" outlet.
Future Mods: Everything I can do to make the car faster and look better!!! But all I have is Im so poor and thats about it
Old 07-06-2006, 06:21 PM
Killa's Avatar
Killa Killa is offline
Re: Running water sound
Can you crank up the car ? check your alternator belt, or go to auto zone, and check for battery and alternator.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-06-2006, 07:10 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I love how you told us you primered your car, even though it has absolutely nothing to do with anything related to your problem.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-06-2006, 07:26 PM
SLoe's Avatar
SLoe SLoe is offline
My turn
Your electrical problems don't sound like the result of a dying battery. If the bat/alt was dying then you would have dim dash lights, and you probably couldn't start it. You said you have no lights so....
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-06-2006, 07:42 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
No idea about the running water problem.
Your dash lights and cd player problem comes from a wiring problem that I'm guessing originates below the cd player, that's where alot of people fuck up their shit.
95 Talon TSI AWD
97 Eclipse GST
Old 07-06-2006, 08:38 PM
ned032002's Avatar
ned032002 ned032002 is offline
Usually when you have that running water sound is when you have your heater on or anything air circulating related. Now from what I've been told, is that when you hear water in your dash like what you are hearing it usually means that the Air conditioner resevoir is filled. And the way that things usually work is the water that is gathered up runs into the resevoir and then runs out a drain that you usually see the water marks on the ground.
The reason that you are hearing water is because the drain is plugged and to un-plug it, put the nozzle of an aircompressor up to the drain which is on the fire wall on the passanger side (near where you are hearing the water). When you blow the air into the drain line, it should un-plug and you should have water pooring out. Good Luck.
Let us know how this works out. I heard this on Car Talk on NPR (National Public Radio), a radio public station around here. I also told this to a friend of mine and he did it on his Lebaron and it did work. So like I said Good Luck.
God I'm Awesome!!!
Old 07-06-2006, 09:45 PM
SLoe's Avatar
God I'm Awesome!!!
ned ned ned, If the water drain were plugged up then there would be no water movement, and thus no sound of running water (unless it was a dripping noise). It would have to find somewhere else to go. Just look underneath to see if there is water dripping out of the AC drain line. OR blow that shit out anyway, you won't hurt a thing.
Ned, you are awesome though. Maybe you are even right on this one. If so then I will you when it comes to diagnosing the sound of a faucet in the dash.
It is just a sound you hear in some cars(i guess, since it's hard to diagnose a fargen sound over the web ) . Just cause you turn off the AC doesn't mean that it won't continue to drain for a little while either. Is the sound bothering you that bad? Is it causing problems? Or is it just an annoyance?(sp?)
Sometimes a lot of air in the cooling system can sound strange as it comes through the heater core, so go to MY "overheated thread" and follow the proceedure for eliminating air bubbles in the cooling system.
BTW, why only in 1st and 2nd? That's furkeded up!
Old 07-06-2006, 09:57 PM
Loeman, are you drunk?
95 Talon TSI AWD
97 Eclipse GST
Old 07-06-2006, 10:05 PM
SLoe's Avatar
HOLY SHIT!! Yeah I've had a few. How'd you know?
EDIT: That's just frikin freaky man.
Old 07-06-2006, 10:24 PM
Hum I said I primered my car because everything worked fine before that dash lights, cd player. The cd player was installed by the previous owner not me, and it worked fine up until then.
I will try to blow the stuff out but I am unsure where the plug is could someone post a pic? If not I can try and find it.
Would this help with the AC not blowing out good on the doors, it blows out good in the middle but hardly any comes out from the doors.
I have no problems starting the car that works fine, could it be where I rest the ECU, can you over rest the ECU? If there is a problem that the cd player is causing how could I fix this. I have installed cd players before and this one is hooked up correctly, I checked because it just went off one day for no reason. I have so many problems!!!:cry:
Mods:
AEM Cold Air Intake
Old 07-07-2006, 12:20 AM
ned032002's Avatar
I'm not sure what it looks like but try it anyways when someone tells you were to look.
Old 07-07-2006, 05:22 PM
SLoe's Avatar
Yeah, and post up if it fixes it. I am curious to see if it works.
You think the primer messed up your cd player? How do you rest an ECU? Do you mean reset?
Old 07-07-2006, 06:35 PM
ned032002's Avatar
Have you tried aiming your vents?
Old 07-07-2006, 09:38 PM
SLoe's Avatar
^pwnt!
Old 07-08-2006, 10:06 AM
Yeah I have tried aiming my vents? ASS!
Yeah I mean reset.
Mods:
AEM Cold Air Intake
