Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-06-2006, 05:36 PM
fundilly fundilly is offline
Sporadic Idle With A/c On
I have a 99 Mustang V-6 5 speed. With no a/c the idle is steady at 800. When a/c is turned on idle goes to 1700-2000 and then fluctuates from 900 to 2000 RPM. Need Help ASAP
Old 07-29-2006, 09:41 PM
N2TRUKN N2TRUKN is offline
Re: Sporadic Idle With A/c On
Check The O-2 Sensors. And If You Took The Cats Off It Will Defantly Cause This Problem. If You Took The Cats Off You'll Have To Put Them Back On Or Reprogram The Computer. Goodluck, Hope This Helps.
