Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-06-2006, 05:46 PM
xskiesgoblackx xskiesgoblackx is offline
b16 wont rev past 3k ??
it sounds like a slower version of the rev limiter and it wont let me rev past 3k. This use to happen once in a while, then i would turn the car off and on and it would be fine. Now it wont rev past it for crap. Ive been checkin all the wires everything looks good. I cant figure it the fuck out. any help would be nice, i was planning on going to new york tomoro. so ill be up all night.
Old 07-06-2006, 07:21 PM
Re: b16 wont rev past 3k ??
i also took the tps off. figuring if it was that, and it was off, theres no way it could do that. ive changed the tps. i cant friggin figure it out.
edit::
i switched the coil in the distributor. and it worked alright for about 10 minutes. then i brought it home. went to drive it about a half hour later and now it wont rev past 3 again. then i took apart the distributor sprayed it all with brake cleaner, put it back together. and it did the same thing. work right for about 5 minutes then out of nowhere it wont rev up again.
Old 07-06-2006, 09:29 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Anything gotten sucked up into your intake/filter box lately?
Paper or plastic...
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 07-19-2006, 03:52 AM
Bunger's Avatar
Bunger Bunger is offline
Most of the time this is a wiring issue with the distributor. Do you have crimp connectors on anything? If so, GET RID OF THEM, they suck. Solder all your joints and use heat shrink. FYI: Not revving past 3k is limp home mode.
