Old 07-06-2006, 01:26 PM
jonphelps1976 jonphelps1976 is offline
2000 z71 5.3 replacement alternator
My alternator is going out and I need to replace it. I believe the current OEM is 105amp, but I have seen a 200amp for the same price. I was wondering if there are any plus's or minus's in going with a higher amp alternator.
I'm guessing this could affect my fuel economy???
Old 07-06-2006, 04:25 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: 2000 z71 5.3 replacement alternator
Higher amp would presumably draw more hp, hurting fuel economy and power, though the change in power may be negligible. There is not any pro unless you are running some SERIOUS aftermarket equipment.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 07-07-2006, 07:35 PM
wrparks wrparks is offline
Likely a negligeable effect on economy, but why would you up it unless you have some major stereo equipment. Stick stock in my opinion.
Old 07-07-2006, 09:47 PM
Elbert Elbert is offline
I don't think the alternator will have any real impact on your fuel economy...
the only impact I know in jumping to a 200Amp Alt would be the need to most likely increase the diameter of the wiring from the Alt to the Battery and to the junction block if it has one...
Unless you have some really big electric loads I would just run the 100 AMP
