Old 07-06-2006, 07:37 AM
intel_guy intel_guy is offline
A/C problem
My 99 1500 4x4 4.8 is not blowing cold a/c. I bought a can of recharge, the kind with an inline guage. I started to pump in some refrig, and the guage was reading 55 lb, but when the compressor kicked on it immediately dropped to 25 lb. When it shut off it went right back up to 55 lb. Any ideas ?
I bought a new compressor/evap/orifice off ebay last year and had it installed because I was haveing a bad noise coming from the compressor pulley (which actually turned out to be the a/c clutch).
Old 07-06-2006, 09:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: A/C problem
Well in the first them Wal mart recharge kits are death kits.
For anyone using them and can kill or injure you and your air cond system.
Here is what you need to safe and proper recharge it.
http://www.ackits.com/merchant2/merc...uct_Code=66773
http://www.ackits.com/merchant2/merc...e=DIY-STARTER1
http://www.ackits.com/merchant2/merc...ode=DIYADVANCE
Now are you just trying to recharge it this year or was it ever recharged and working last year after the compresser and stuff was replaced?
If recharge last year what was it recharged with?
Was the right air cond oil put in it? was it pimped down and a vacume pulled on it
Did that death kit you are trying to kill it with have any stop leak crap in it?
Is it a blend freon or the good R-134?
Tell us more and get a pressure reading on the high and low side with the proper recharge gauge at idle and at 2000 RPM with the compresser running?
And post back pressure readings.
MT
MT
Old 07-06-2006, 07:18 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
Re: A/C problem
MT-2500 has a good point. Don't ever use the cheap crap w/the sealer in it. Use only R134, and don't use the florescent "leak detector" either. I hate that stuff.
The pressure drops and rises because the compressor kicks off/on. It's low on freon. There's a 99% chance that the compressor has a leak. I have replaced too many to keep track of. New (A.C.Delco) units aren't cheap and the cheap rebuilds are junk. Visteon came up w/a revised design that aren't prone to case leakage. If you do replace the compressor, get advice (or have someone else do it) from an expert.
Old 07-06-2006, 09:12 PM
Elbert Elbert is offline
Re: A/C problem
I agree on the "death Kit" statement. You should not screw around with the A/C unless you know what you are doing. I'm suprised that product liability issues have not forced those parts shop A/C refills off the shelf.
Old 03-09-2007, 09:01 PM
Re: A/C problem
Is the Visteon compressor better than the OEM Delphi? Visteon is sold at carquest and local parts shops. I let the compressor go all winter and now am gonna have to replace it. Of course the ebay seller (aircoparts.com) is completely unresponsive when it comes to warranty on the part I got from them.
