Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-06-2006, 12:17 AM
movieprops movieprops is offline
Please help!!
I have a 1993 Acura Integra with an automatic transmission. I was driving a long distance the other day in hot weather, (Aprox. 100 degrees), and after about 45 miles into my trip the transmission started to slip as if it was low on tranny fluid. I exited off the freeway and found an auto parts store. When I pulled out the dip stick, a poof of smoke came out, like the tranny was hot, and it seemed a little low. So I put about 1 quart in, and it seemed to do the trick. But, when I got to my destination, it started acting up again. I put a little more in, and drove back home. I almost made it home before it started doing the same thing. I put a little more fluid in, and it got me home. Can the problem be that the tranny is overheating and when I put in new cool fluid it cools the tranny enough for it to run until it gets too hot? If so should I install a tranny oil cooler? Oh, by the way there are no leaks. Can somebody please help!!
Old 07-06-2006, 01:13 AM
lover707 lover707 is offline
Re: 1993 Acura Integra Transmission Overheated?
maybe it is leaking.. it looks like only 45 miles down the road and u lost a quart of tranny oil.. u might have to get a new used tranny case..
Old 07-06-2006, 09:34 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Yea, check for leaks under your car. It would take alot of heat to actually burn the oil off that fast.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-06-2006, 11:47 PM
There is no leak. Can it just be that the oil cooler in the radiator wasn't doing the job, and I need to put in a seperate oil cooler?
Old 08-09-2006, 02:27 PM
Any real Experts out there?
Isn't there any real experts that can help me? I have a 1993 Acura Integra with an automatic transmission. I was driving a long distance the other day in hot weather, (Aprox. 100 degrees), and after about 45 miles into my trip the transmission started to slip as if it was low on tranny fluid. I exited off the freeway and found an auto parts store. When I pulled out the dip stick, a poof of smoke came out, like the tranny was hot, and it seemed a little low. So I put about 1 quart in, and it seemed to do the trick. But, when I got to my destination, it started acting up again. I put a little more in, and drove back home. I almost made it home before it started doing the same thing. I put a little more fluid in, and it got me home. Can the problem be that the tranny is overheating and when I put in new cool fluid it cools the tranny enough for it to run until it gets too hot? If so should I install a tranny oil cooler? Oh, by the way there are no leaks. Can somebody please help!!
